Posted July 21, 201114 yr Only one sub rite now the other one will be in on Tuesday. Box is 7.1 cubes tuned @ 30hzHit 144.4 sealed up at 43hz without much testing. 146.7 outlaw.
July 21, 201114 yr Author Damm! Can i upload pics from an iphone? To this thread? They are already uploaded to photobucket.
July 21, 201114 yr Bracing inside the boxFi Audio logoClick on reply and look at the code. You also have to clear the http:// out of the box before you paste.
July 21, 201114 yr thanks for the help No Problem!! Enclosure is looking good!! What is this going in and with what power??
July 21, 201114 yr Author Painted the Fi logo to match the color of the Tahoe kinda...Running all stinger 8 gauge to the subSub inSecond sub will be in Tuesday Fi Q 15"
July 21, 201114 yr Author Will get more pic up when i get more paint. Autoparts ran out () and once the second subwoofer is in.
July 21, 201114 yr Author thanks for the help No Problem!! Enclosure is looking good!! What is this going in and with what power?? will be running off a Soundstream 1.3400 @ 0.5 ohm in a 02 Tahoe. just one gets loud im anxious what 2 will do!
July 21, 201114 yr thanks for the help No Problem!! Enclosure is looking good!! What is this going in and with what power?? will be running off a Soundstream 1.3400 @ 0.5 ohm in a 02 Tahoe. just one gets loud im anxious what 2 will do! How do you like the 3400?? Searched for those when I put my son's system together, but ended up with 2-2200s. Keep us posted on the progress!
July 21, 201114 yr Author It is a great amp! Very powerful and clean. It heats up a bit when i drop voltage but definatly a great amp. You went with 2 Soundstreams 2200's?And yea sure will thanks.
July 21, 201114 yr It is a great amp! Very powerful and clean. It heats up a bit when i drop voltage but definatly a great amp. You went with 2 Soundstreams 2200's?And yea sure will thanks.Yep, in his Eclipse
July 21, 201114 yr Author It is a great amp! Very powerful and clean. It heats up a bit when i drop voltage but definatly a great amp. You went with 2 Soundstreams 2200's?And yea sure will thanks.Yep, in his EclipseNice. Its on the build logs right? Ill check it out
