Posted July 25, 201115 yr My brother is getting an IDQv3 12" sub. Going to be powered by an arc audio 600w amp. Down the road he's going to get another sub and another amp to match. Our budget is drained so I'm going to attempt to build the box. I wanted to go ahead and build a dual 12" ported box tuned at 30Hz. and just use one side for now. Any recommended web sites and pointers would be greatly appreciated. Some questions I have are what's the best to hold the box together. Pre Drilled hole and screws, or staples, or glue, or all the above. Round port vs. rectangular. Which direction to aim the port. Should I aim subs toward the back glass tilted slightly up.
July 25, 201115 yr i dont suggest building for 2 subs and only putting one in, the cubic feet will be huge and will bottom out on to much power
July 26, 201115 yr Port on each sides? Or port down the middle, if you do build the box just divide down the middle and port on each side.
