Posted March 5, 200422 yr Free box plans for RE HC 12" I promised over on caraudio.com.....Thats one way to get the kiddies to come here and have a peek
March 12, 200422 yr Hey LR.. how many cubes is the RE HC 12 box (before/after port displacement).. and what is the box tuned to? I'd figure it out myself.. but I don't have the slightest clue as to how I'd go about doing that.. lol. Also, thanks alot for all the free box plans your givin out...really killer
March 12, 200422 yr Author Hey LR.. how many cubes is the RE HC 12 box (before/after port displacement).. and what is the box tuned to? I'd figure it out myself.. but I don't have the slightest clue as to how I'd go about doing that.. lol. Also, thanks alot for all the free box plans your givin out...really killer about 3 cubes after all displacement (slightly less) and 34hz tuning.
March 12, 200422 yr you sure thats enough port area for a xxx 15? my 12 got waaay louder when i went from 16 to 42.5
March 13, 200422 yr Author you sure thats enough port area for a xxx 15? my 12 got waaay louder when i went from 16 to 42.5 That box is specifically designed to have a flat response curve. If you'd like to modify the plans for an SPL application, be my guest
March 17, 200422 yr Author You wouldnt happen to have plans for 2 XXX 15's now would ya? why yes, i would$10
March 24, 200421 yr What would the port be for the HC if it was circular? I do not have the space to do the slot port.
March 24, 200421 yr Author What would the port be for the HC if it was circular? I do not have the space to do the slot port. i'd recommend 2 4" ports about 15.6" long each
March 24, 200421 yr how massive is a box for two 15 D2s, trying to decide if I have room or should wait on the 12s.
May 12, 200421 yr if i wanted to go about adjusting that to make is a spl box for the 15' xxx what would i have to do
July 30, 200421 yr what will happen if i used my 12" sub, on the 15" box ??be better , or it will suck ??
August 2, 200421 yr if i wanted to go about adjusting that to make is a spl box for the 15' xxx what would i have to do i bet on it that no one will reply i wanna know too !!
