Posted August 1, 201114 yr Hey all. I have my Fi SSD 15 in a box right now that is tuned wayyy to high. So I was crunching some numbers for a new box. Here are the specs, can you all look over them and see if everything is correct please?28" wide17" tall28" deepPort:4.5" wide15.5" tall41" longSub up port back.3.9 cubes net, @ 31hz, 17.88 sq in of port per foot Also with that box, should an SSD 15 hit the lows pretty good?
August 2, 201114 yr Hey all. I have my Fi SSD 15 in a box right now that is tuned wayyy to high. So I was crunching some numbers for a new box. Here are the specs, can you all look over them and see if everything is correct please?28" wide17" tall28" deepPort:4.5" wide15.5" tall41" longSub up port back.3.9 cubes net, @ 31hz, 17.88 sq in of port per foot Also with that box, should an SSD 15 hit the lows pretty good?thats gonna be a big A$$ box my friend. should pound good
August 2, 201114 yr where in MO are you from?well with the given dimensions you get 6.29912 Ft^3 with .75" wood.
August 2, 201114 yr Author where in MO are you from?well with the given dimensions you get 6.29912 Ft^3 with .75" wood.Well, It's only the box that you designed silly :-)
August 5, 201114 yr Should pound pretty great! Good luck! You do know Fi recommends like 3-4 cuft for a Fi 15" right? lol
