Digital Designs Z2LV, Z-SE, or M4A? Just a thought. I would like to see what you guys think and what kind of numbers have you seen from actual tests.
come on guys, just for sh**s and giggles I'd like to see what kind of numbers these monsters actually put out. Not a verses thread just some general power talk.
You honesty think your average joe blow can accurately compare amplifier power ratings?
Using a dmm and a clamp doesn't mean much, and most aren't going to have a bench power supply and so forth.
Thanks. I figured someone who knows their stuff has put at least one of these through an actual, reliable test and would chime in..
Even if they did, it would be different if you were to put that same amp in your setup. Different setups will cause different results, too many factors to make them reliable. If someone were to get 5k out an amp, it doesnt mean you will in your application.
