Posted August 20, 201114 yr 500 non clamped (calculated using sub impedance and amp voltage with 50 hertz test tone) with Hifonics Brutus ampsong played is Mr. Magic "I Smoke, I drink" Edited August 20, 201114 yr by Audibel Customs
August 30, 201114 yr Author Genesis motor coned to a 15" with same 500 watts in a 6th order bandpass same 10" in 6th order bandpass in a 2010 civic trunk. Again on 500 watts
August 31, 201114 yr Author Remember these are 6th order bandpass so they are a little louder than a typical ported box. But they allow me to see what the coils and motors can handle. These are in no way "spl" sub either. After all they only have 15 Bl. My Devine series with 375 bl^2/re motor force factor will be geared for daily groundpounding. I had two goals for this line when I approached Dan. No. 1 sound as good and outperform a JL w6. No.2 be able to price these subs cheaper than a w6 while keeping dealer's margin higher than the JL. So what this means is the typical customer looking for a w6 or similar sub can buy a better sub at a cheaper price while the dealer makes more money than they would on the other sub.
September 2, 201114 yr Author Genesis motor coned to a 15" with same 500 watts in a 6th order bandpass The enclosure is 2.5 cubes per chamber with the front tuned to 55 hertz and the rear tuned to 20 hertzsame 10" in 6th order bandpass in a 2010 civic trunk. Again on 500 watts
