Posted August 25, 201115 yr so im pretty new to going to competitions and competting my subs. i was just wondering if only one has any tips or tricks i could use to help gain dbs?? anything will help i just dont want to go in this competition that is coming up and not know something to help me.. i drive a two door tahoe i have 4 12's ppi pcx subs and i was wondering if i folded down my back seat and moved my subs closer to the front would that help (probably a dumd question but you never know until you ask)
August 25, 201114 yr Idk dont have experiance in that question would like to know also. Edited August 25, 201114 yr by Dictator
August 25, 201114 yr Check out the link belowtips and tricks to gain DBsWhat kind of comp. are you going to? Iasca, usaci, Meca?
August 25, 201114 yr Check out the link belowtips and tricks to gain DBsInteresting read. Was perplexed by the results of removing the 45s. Great things to think about.
August 25, 201114 yr Is the show in Tulsa, Bixby or Enid? The next show in Bixby on the 11th is a MECA event, the 25th in Tulsa is MECA state finals, the Enid show I'm not sure about but is probably USACI. I'll help you if I can, pm me if you would like. I'm in Seminole btw and I'll be at the 2 MECA shows in September.
August 26, 201114 yr Author What have you hit before? And what is the location of your port?this will be my first time getting metered and my port is in the middle of the box and it faces my back hatch
August 26, 201114 yr Author Is the show in Tulsa, Bixby or Enid? The next show in Bixby on the 11th is a MECA event, the 25th in Tulsa is MECA state finals, the Enid show I'm not sure about but is probably USACI. I'll help you if I can, pm me if you would like. I'm in Seminole btw and I'll be at the 2 MECA shows in September.its the one in bixby on the 11 and if i can im going to try andmake it to the one on the 25th
August 26, 201114 yr Author Check out the link belowtips and tricks to gain DBsWhat kind of comp. are you going to? Iasca, usaci, Meca?i believe its meca cause thats the site i found it on
August 26, 201114 yr Charge your batteries all night before the show ... and do not play your radio on the way to the show or before your SPL run and use up much needed juice for the frequiency sweep and burp ... just a suggestion ...
August 26, 201114 yr Author my port is not the best port me and my buddy that built the box arent any good at figuring out ports so i went on to 12volt.com and did there port clac and it said to make a 6x6 square port 11'' deep which i dont think is bigg enough for my subs so this weekend we are redoing the port and putting 2 6'' round ports each 20'' long
August 26, 201114 yr The 11th and 25th shows are MECA events. Do you know what class you will be running in? I can give you some tips and pointers for competing in MECA. Since you have never been, you will likely want to be in the Amatuer Street division and in this division, you have to do your run with the car off and music only (remember, no foul language is allowed either) you are not allowed to have the car running and no tones. If you choose to use tones and/or have your vehicle running, you will be placed in the Street class most likely (this depends on your install/vehicle and whether or not any part of your system is above the window/back seat, any other mods) What type of vehicle are you using? What size subs and how many? What amp/s? What do you have for an electrical system? Answer these and we can help put you in the right class and on to the winners circle!
August 26, 201114 yr Author my box is not above my window or back seat i have 4 12'' ppi pcx and im running a 1500 mb onyx ive done my big 3 and i have 2 batteries under the hood my box is 6.5 cubic ft i have a 97 two door tahoe.
August 26, 201114 yr my port is not the best port me and my buddy that built the box arent any good at figuring out ports so i went on to 12volt.com and did there port clac and it said to make a 6x6 square port 11'' deep which i dont think is bigg enough for my subs so this weekend we are redoing the port and putting 2 6'' round ports each 20'' long6x6 would be 36in^2 of port area,And 2 6" would be, πr^2 per circular port, thus 2(π3^2) = 56in^2 of port areaThis should help.
August 26, 201114 yr That should be a great setup in AS3 for a first timer. I believe that amp has a pair of 70 fuses on board right? So 140 total amps of fusing with four 12s puts you in AS3, S3, DB3 classes, if you want to run a smaller fuse inline before the amp, you can drop down to a 50 amp fuse and run in AS2, S2, and DB2 class.
August 26, 201114 yr Author yes it has 2 70 fuses and i dont want to drop down classes i want to see what it well really meter out at. i know i probably win, im in it because i love bass!!!! lolso as3 would be the best for me to run in?
August 26, 201114 yr my port is not the best port me and my buddy that built the box arent any good at figuring out ports so i went on to 12volt.com and did there port clac and it said to make a 6x6 square port 11'' deep which i dont think is bigg enough for my subs so this weekend we are redoing the port and putting 2 6'' round ports each 20'' longHere is a site you can click around on for info on port size calculations.
August 26, 201114 yr You will have to be in AS3, S3, or DB3 with that amount of cone area and fusing. You will also be in my class most likely, unless I decide to drop down to 2.
August 26, 201114 yr Author You will have to be in AS3, S3, or DB3 with that amount of cone area and fusing. You will also be in my class most likely, unless I decide to drop down to 2.what are you running?
August 26, 201114 yr Great post Stefan, I couldn't have said it better myself I might make some simple calculators later to make things easier for people. Guess I should check and see if it's all the same to the12volt calcs.
August 26, 201114 yr Great post Stefan, I couldn't have said it better myself I might make some simple calculators later to make things easier for people. Guess I should check and see if it's all the same to the12volt calcs. It is, it uses Vance Dickason's formulas.
August 26, 201114 yr Great post Stefan, I couldn't have said it better myself I might make some simple calculators later to make things easier for people. Guess I should check and see if it's all the same to the12volt calcs. It is, it uses Vance Dickason's formulas.Heh then no need for another calculator with the same formula. They don't list a calc for minimum port area though?
August 27, 201114 yr Author I will be running a pair of SA15s for the shows on the 11th and 25th.sweet i cant wait to hear them ive seen them on youtube but never heard them in person
