Posted August 26, 201115 yr for 4 sa8's d4's so i csn run 2 ohm or .5ohm nominal..... ive got a dc 270xp alt and 2 discovery dt12-4000 agm g31 batterys. was thinking a saz2500 @ .5 nominal
August 26, 201115 yr .5 on a SAZ2500 would do great for burps and you could wire to 2 ohm for daily. I think that would be a sweet setup and have been thinking about doing something similar.
August 26, 201115 yr Author wouldnt be enuff power @ 2ohm daily... its have tro be @ .5 daily... i dont burp
August 26, 201115 yr Author considering a cresendo bc5500d ran daily @ 2ohms... which would give me plenty of power and once the sundown x8"s are released i can swap the sa8s out for the x8s then use the amp to its full potential.. at this point ths is what im leaning towards the most.. id love to do a saz4500 @ 2ohm but they are pretty pricey and dont really wanna go with a used amp.. unless it was one hell of a deal
August 26, 201115 yr Buy my DD m3a for 500, same power as a saz-2500 for cheaper, Bnib never been powered!
August 26, 201115 yr Buy my DD m3a for 500, same power as a saz-2500 for cheaper, Bnib never been powered!Good amp, good guy.
August 26, 201115 yr wouldnt be enuff power @ 2ohm daily... its have tro be @ .5 daily... i dont burpbuild a more efficient enclosure then
