September 2, 201114 yr My vote goes to an xcon. Your amp is perfect for it and too much for a q. Or wait for the ia sale. I'm pretty curious about that.Amps have gain knobs for a reason.
September 2, 201114 yr My vote goes to an xcon. Your amp is perfect for it and too much for a q. Or wait for the ia sale. I'm pretty curious about that.Amps have gain knobs for a reason.Lol, say what?!?
September 2, 201114 yr If I had this car I would get the JL Audio stealthbox for the 2010 up Mustang It has a 13w3 in it. Personally I wouldnt stick a box in the back. Keep it clean looking!
September 2, 201114 yr Author Oh, don't worry... It'll look clean . Stealthbox makes it hard to get my clubs in the car. I'd be banging it and scratching it.
September 2, 201114 yr If you are going to seal the trunk off from the cabin, I vote go with an infinite baffle setup.
September 2, 201114 yr If you are going to seal the trunk off from the cabin, I vote go with an infinite baffle setup.Or bandpass.
September 2, 201114 yr Author I've never heard an IB setup that was clean enough, nor loud enough.... Bandpass? Did u look at my available dimensions? Haha.
September 2, 201114 yr I had a single 10" Cerwin Vega IT with 300 watts in my new Edge SN95 and it was loud enough. I had longtubes, and off-road H-pipe, and 2 chamber flows, and the quiet whine of a Vortech.
September 2, 201114 yr I've never heard an IB setup that was clean enough, nor loud enough.... Then it must not have been done correctly. It's more work then a traditional box. But looks so much cleaner. If your worried about output, stick two woofers side by side.
September 2, 201114 yr Are you able to fit a box with the dimensions you mentioned into the trunk? I used to own a 95 and my dad had a 05 and I noticed that there was no way I could fit the box from my 95 into the 05. The 2012 Mustangs seem to have the small openings like the 05 so it may be a problem trying to get a box in there. And whatever you find out, let me know. I want a 2012 myself.
September 2, 201114 yr Author Your prob right DeYoung... Neither setup looked very "quality" oriented. I'm pretty sure I'm gonna want more than a single 10. I have a re sx 12 that needs a recone. Maybe I should try that in like 2.0ft^3 tuned to like 35hz.... Don't have the space for a long port for lower tuning while still having the slot port at least 2" wide ....
September 2, 201114 yr Author Yes king alpha, I made a cardboard box to that dimension and I can get that in easily... Good looking out though, I'd have been pissed if I built it all and couldn't get it in! Haha. Thanx
September 3, 201114 yr Thats a nice ride but I'd say a single ported 12 would be ur best bet and a fully loaded fi bl, xcon as previously stated, a nightshade or zv.3 I'd say btl n2 or n3 but they are a little bit higher than your budget
