Posted September 5, 201115 yr I know ppl tend to get tired of the old this or that threads but a I am really getting ready to step to the plate. I am walling my 92 Honda Civic Sedan and have prob 15 cubes net. Should I run 3 15" Incriminator Audio Leathal Injections, or 2 18" death rows? Power will be between 2500- 3000 watts? Thank you guys for your suggestions
September 5, 201115 yr Cone area is similar, there probably won't be much difference in output either way. What are your goals for this system?
September 5, 201115 yr I'd go with the 3-15" just because I agree with anything duran says ... .. And I'd like to see the setup ....
September 5, 201115 yr Author you guys will because I will be posting build logs on some of the forums.
September 6, 201115 yr Admin Get a pair of FL 18's, skip the competitions and seal them up. Oh wait, what you wanted.
September 18, 201114 yr Author Here is the link to the build log:http://www.****/forum/build-logs/98078-4-ia-15s-little-car-team-dtf-build.html
September 18, 201114 yr Author ok check out caraudioclassifieds for the build log under 4 IA 15's in a small car
September 18, 201114 yr Admin ok check out caraudioclassifieds for the build log under 4 IA 15's in a small carWhy not post it here where IA people are and the IA forum is.
September 18, 201114 yr ok check out caraudioclassifieds for the build log under 4 IA 15's in a small carWhy not post it here where IA people are and the IA forum is. I don't wanna have to go over there for updates.
