Well I started building me a new subwoofer box for my fusion powerplants FPW 1200. figure ill post some pics of it on here. It was design by nightmareaudio.com accept for the plexiglass window I put that in. Right now im about to start painting it. but heres the pics. have any questions feel free to ask
outer shell
half temp assembled
almost totaly assembled
router port edge
gut assembly drying
screws that im using for the subs
working on framing up for the plexiglass
Testing some light positions
Pretty much finished
Looks sweet! How does putting the subs in the ports change things, is it a tapped horn?
Thanks.....no. its really a 6th order bandpass....with the sub firing into the port like that it works as a front chamber.....it is pretty much just a fancy looking slot port box that front chamber does not make much difference in the output.
I like that the subs are protected. I've wanted to make a tapped horn for a while now. But I haven't figured out hornresp.
