Posted September 12, 201114 yr Quick question... What would 6 dual 2 ohm subs wire down to? For example... If I got 6 SA-8s d2 what ohm would they wire to.. Lowest ohm together or all possibilities.
September 12, 201114 yr Author Ok I guess I should have stated lowest at 1ohm or higher sorry, so 6 d2 can wire down to 1.5 ohm? That should be perfect
September 12, 201114 yr The word you are looking for is "impedance".Hmmm....yes....nominal impedance....
