Posted September 16, 201113 yr alright so i just received my xs power d3100 battery...now how am i supposed to connect 4 1/0 gauge wires to it ??? do they make special terminals that hold 4 1/0 gauge wires or do i have to make my own ??
September 16, 201113 yr you can use scews and washers and lock washers!or better yet make some buss bars!and I can't seem to find a pic of my nice buss bars. they are simply a piece of 1/4" aluminium with 4 tapped holes drilled in them and one cleanance hole for the main screw to screw into the battery terminal!
September 16, 201113 yr Author you can use scews and washers and lock washers!i was thinking about that... so have 1 screw/bolt holding the 4 ring terminals on top of each other ??what do i make them out of ?? Edited September 16, 201113 yr by b00sted
September 16, 201113 yr bolts, longer bolts. Or you could get some nice terminals made if you want to spend a little cash.
September 16, 201113 yr you can use scews and washers and lock washers!i was thinking about that... so have 1 screw/bolt holding the 4 ring terminals on top of each other ??what do i make them out of ??I just added a pic for you of how I did mine back in the day sorry I couldn't find a pic with my buss bars but I should take one lol! and you cna use screws from home depot if you are really cool use some brass copper screws lol!
September 16, 201113 yr Author alright ill just connect them all to one stud... sounds good to me lol...thanks guys
