Posted September 22, 201115 yr I was set on buying some SA12s and a sundown 1200d, until I saw Lethal injections on sale here for 151 each. Which ones are better, SA12 or LI12???I like low end bass on rap songs.I built a box for the SA12s, would the LI12s fit in 3.2ft at 30hz?I'm terrible with decision making when it comes to buying something!
September 22, 201115 yr i have no expierience with either, sure both are great...but i would go with IA just to be different
September 22, 201115 yr Either will work well for you. Both subwoofers are high quality and both are made by a+ companies.
September 22, 201115 yr Author If you could chose between the two running on a sundown 1200, or any other amp suggestions?
September 22, 201115 yr Author So what im getting is their both equal subs. Meaning it all comes down to price. Therefore the lethal injections would be the best bet?
September 22, 201115 yr Author I see so many good things about sa12s and sundown, nothing on the incriminators. This will be my first highish end build. Im upgrading from two p2s on 550 rms. Next paycheck equals two incriminators I guess!
September 22, 201115 yr Incriminator does no mass advertising like sundown does, they are both great subs....but i would choose the IA just to be different
September 22, 201115 yr You can't go wrong with either. Tough choice, if you would like to try out Incriminator Audio though, now is the time as you will never see these prices again.
September 22, 201115 yr You can't go wrong with either. Tough choice, if you would like to try out Incriminator Audio though, now is the time as you will never see these prices again.ever?
September 22, 201115 yr You can't go wrong with either. Tough choice, if you would like to try out Incriminator Audio though, now is the time as you will never see these prices again.ever? Maybe in three years.IMO I would go with the Li's, but the box you have built isn't really optimal for them.
September 22, 201115 yr Not on brand new product. I would bet that the price of all this stuff is going to increase in the next 3 years, unless quality decreases and I don't see that happening.
