Posted September 24, 201115 yr So my build calls for my 4" aeros to be about 38" long so I have to do some piping in my box with 90 and 45 degree turns. When measuring I'm assuming I stay in the middle the whole time and measure flare tip to tip? The turns are what throw me off when measuring. Thanks guys
September 24, 201115 yr Are these true Aero's? Precision Ports? If so, They will come with directions and formula's you will need to calculate the port length. Edited September 24, 201115 yr by Chris
September 25, 201115 yr Author I think there's a misunderstanding here. I'm just asking how you measure it, I know it is simple but I'm just not sure. I have 1 90 and 1 45 degree angle turn on each of my ports.
September 25, 201115 yr Can't you measure the total length of the elbow, then subtract the amount on each side where the pipe slips in?
