Posted September 27, 201115 yr hi guys my question is. can a low battery bank cause my mmats hd 4000.5 to clip pre maturely.
September 27, 201115 yr Author I have a kinetk 1400 up front an dc 270xp alternator. subs: 2 12 fi btl on a mmats hd 4000.5.box tuned to 35hz and a group 27 battery in the trunk.
September 28, 201115 yr Author yesCan u tell me why.and what are the benefit of having beter battery cause I do listen to my music with my engine off
September 28, 201115 yr yesCan u tell me why.and what are the benefit of having beter battery cause I do listen to my music with my engine offYou listen to it at full volume car off?
September 28, 201115 yr Author Typo I don't listen to it with the engine off.so what are the benifits of have batteries in the trunk.
September 28, 201115 yr Typo I don't listen to it with the engine off.so what are the benifits of have batteries in the trunk.supply and demand
September 28, 201115 yr YES!Take a DMM and measure current draw at the amp when playing to find out how much voltage drop you have. Did you do the "Big 3"? How many runs of 1/0 power and ground cable do you have?
September 29, 201115 yr big 3 done and 2 runs of 1/0 power and chassis groundHere's from my personal experience. Basically, you have a good alt, need more batts... I had stock alt but good batts.Say I listened to a specific song, happened on quite a few songs actually- with my stock alt, voltage would get down to 12.0-12.3 and start clipping. Now, I can sit at over 14.0V on the same song, actually turn it up louder and don't experience any clipping. Look into adding an extra battery, like the XS D3100 should do the trick.
