October 11, 201115 yr Author ill be ording the sub and amp at the end of the month so stay tune because the zcon 18 will be slamming soon
October 11, 201115 yr Author what you guys think after displacment 6,7, or 8 cubic ft and slot port or precision port
October 11, 201115 yr what you guys think after displacment 6,7, or 8 cubic ft and slot port or precision portYou would need to many aero ports to be practical. Based on the power I'd recommend 6^3 net.
October 12, 201115 yr I say 7+ cubes if you can. 6 is a little on the small side for 2500w.but what do i know
October 12, 201115 yr I say 7+ cubes if you can. 6 is a little on the small side for 2500w.but what do i knowI agree, I would shoot for 7 cubes net given the power.
October 13, 201115 yr more important than the volume and port placement...PICSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSS
October 16, 201115 yr Author ok guy's I need some help I want to build a system that does 150db with no problem what subs,amps should I buy. I want my VDub to slam and I dont want to spend tons of money and end up not liking the subs.
October 16, 201115 yr ok guy's I need some help I want to build a system that does 150db with no problem what subs,amps should I buy. I want my VDub to slam and I dont want to spend tons of money and end up not liking the subs.Buy whatever you can afford? Read the rules before posting again bro, nobody can suggest a 150db system off the top of there head with no budget, space restraints and so on.
October 18, 201115 yr Author I ended up getting 2 Fi Btl subs for $200 and the box just have to recone them so now it's time to buy the re cone kits anyone know any dealers in florida for Fi since their slow at getting you your stuff I hear.
