Posted October 14, 201114 yr Well, I planned on doing a 3cuft box ported to 33hz in my lincoln ls. As usual I have read a lot about the sub before purchasing it, and in several different locations it has said that i should use the flatwind coil option,however in different locations i have also read just the opposite, it said that i should use the "stock" copper coil for a ported enclosure...i figured i would be able to get the best advice here and the most accurate information. Also what about the cooling option?I have nothing against buying a decent amp, i would get a BL or something but the SSD is a great daily and i drive an hour to work and a hour home so i need a daily lol...If i need to feed it 1000-1500 True RMS then i have to feed it 1000-1500 rms, i dont mind lol i just need to know what to shop for.thanks for all the help guys..appreciate all forms of advice.
October 14, 201114 yr The Fi site lists the differences between coils and other options, https://ssl.perfora.net/www.ficaraudio.com/sess/utn;jsessionid=154e8fa5e5cfb68/shopdata/0070_Tech/0070_Speakers/product_overview.shopscriptThe BL is a daily driver as well...
October 14, 201114 yr The bl is a daily sub just as much a's it's a spl sub. It's a mix of both. But find a clean 1500 watt amp so you'll have a little headroom. Get the cooling option if you run over rms
