Posted October 18, 201115 yr needs some opinions on a good 1/2 din eq for under 150. just what some people are using. the main thing that i want is two inputs not aux just frt and rear with three outputs but if i have to i can do without.
October 18, 201115 yr I don't quite understand what you actually want.Sorry to say this, but punctuation would definitely help.The only one I've used is the kicker KQ5.This has 2 inputs, one is an auxiliary.It also has a front and rear output.This is a 5 band quasi-parametric eq..It served the purpose I needed it for very well.
October 19, 201115 yr An EQ to add an EQ is stupid. If you don't have a reason to "fix" something then it will only make your system sound worse. Of course, knowing what you need to fix may either give us an easier or alternative route, but if not at least we can recommend an EQ that will do what you need.
