Posted February 3, 200620 yr Well were do i start... lets see i currently have a nINE.1 running my 12" mag d2... this month i will be ripping my car apart to deaden it >_< that mag rattles my car like crazy... anyways... im thinking of getting another 12" mag for sure also i have the thought of possibly getting a total of 4 and just taking my rear seats out but my main question is should i get new amps when i get my other mag or if i go with the 4 should i change my amps out?? or just buy some more nINE.1's this wont be for like 2-3months because 3 mags arnt cheap plus the cost of amps...
February 3, 200620 yr Admin the Incriminator 20.1 might be a great option if you want to upgrade and you are running 2 MAGs
February 3, 200620 yr Author the Incriminator 20.1 might be a great option if you want to upgrade and you are running 2 MAGs<{POST_SNAPBACK}>ok cool, those go for like 1000$ dont they? and they put out 1800w so 900 each sub?? i was looking for atleast 1200w a sub was looking at the Z7000 as well it puts out 1500w@1ohms was thinking maybe 2 of those if i get 2 mags or 4 if i get 4 or should i just get 1 amp to run all 4? or 2 w.e. i decide to do..
February 3, 200620 yr the Incriminator 20.1 might be a great option if you want to upgrade and you are running 2 MAGs<{POST_SNAPBACK}>ok cool, those go for like 1000$ dont they? and they put out 1800w so 900 each sub?? i was looking for atleast 1200w a sub was looking at the Z7000 as well it puts out 1500w@1ohms was thinking maybe 2 of those if i get 2 mags or 4 if i get 4 or should i just get 1 amp to run all 4? or 2 w.e. i decide to do..<{POST_SNAPBACK}>The 20.1 go for around 700. You can get a discount if you search around. I will be picking one up as soon as I sell my current amp for $525.If you run mags you will want to run the mp at .5 ohm. It is fine for the amp MUCH more power then 1800rms I promice. More in the range of 2200rms @ 1ohm, so you are looking at quite a bit at .5.
February 3, 200620 yr Author ok cool, so thats like 1400$ or so for amps and another 1100$ or so for 3 more subs, and probably like 300-400$ for my noise dapening mats, and then the cost for the box's wich i will have made for me, 300-400$ plus all the wiring ^.^ im looking at like 4000$ easy... woohoo i start saving 2day no more lunch for awhile i guess...
February 3, 200620 yr well you do know the 9.1 with good voltage will put out 1500w @ 1ohm so 2 of them at 1ohm will give you like 2800-3000w ,and you can bidge lower ,people use them at .5-.75ohms all day long just a suggestion
February 3, 200620 yr Author well you do know the 9.1 with good voltage will put out 1500w @ 1ohm so 2 of them at 1ohm will give you like 2800-3000w ,and you can bidge lower ,people use them at .5-.75ohms all day long just a suggestion<{POST_SNAPBACK}>ooo so i can get another nine.1 and run em both at .5 and 1 for each sub? that wi;l; save me some $$ but then again i dont wanna push the amps 2 hard :/ anyways i was thinking 4 12" mags facing up ^.^
February 3, 200619 yr I wanna see some current tests on the 20.1I have thought about the amp, but I just found a BPX2200.1 I might grab.
February 4, 200619 yr yea you can run them at that ohm load ,as long as you have good voltage ,and dont go crazy on the gain settings ...DELVRYBOY i think thats his name burped the 9.1 at .12 ohms so they can take a beating
