Hey guys!!! So I am currently running a box built from Dave the box guy. Its 2.5 cubes after displacement, tuned at 35 hz. I have a the ssd with flatwound and bp power, a 2010 model.
Anyway, I LOVE the way this thing sounds. But I got to thinking.. I know that Fi Recommends the max ported box space to be 2.5 cubes, and thats what I run.
But I am still a novice, and got curious about mechanical handling... Would running this at 1000 watts rms daily (MB Quart ONX 1500.D amp) be okay to do?
Cuz thats what I am running, with the amp tuned as well.
Just wanted to make sure that may check out okay, or do I need to reduce my amps tuning?
Thanks guys!
-Chance
You're fine, the SSD is rated at 1,000 watts rms. As long as you're in the box recommendations, why would you be worried? Not to mention you got the bp option. Keep that thing slamming! :drink40:
what is you amp SSF set to? subsonic filter...
As Shogen asked, the SSF would be my only concern.
^^^... please lower your volume during usage until you can answer ... please... please... please... :)
if you read this... turn your dial almost all the way to the last mark @ 35hz... slightly under it will be okay...
Sorry for keeping you on edge man!!! Sorry sorry sorry!! lol. I just got home!!
Thats what I failed to mention, it is slightly (very slight) below 35 hz so Im good on that. I knew not to mess up like that again (that was how I ruined my first system years ago).
I figured I was just worrying about it, but I just wanted to be safe on this new box setup!!
Thanks for the help guys!!
-Chance
