April 10, 201313 yr Curious if you ever got clamped measurements of the Crescendo amps at 16v? Also, any chance of this being in Indy June 15/16 for Slamology? I would love to get a demo of this beast!
April 10, 201313 yr Curious if you ever got clamped measurements of the Crescendo amps at 16v? Also, any chance of this being in Indy June 15/16 for Slamology? I would love to get a demo of this beast!I second that!! i was curious of the same thing.
April 13, 201312 yr something about zcons that make me go nutz!!!!! SSA FTW! They are now Evils inside
April 14, 201312 yr Author with the zcons we clamped 9k out of the pair but that was rising to 5ohm straped at that frequency. will have to clamp it agian with the new subs (different starting impedence) did make some pillars for it today as well. also got over the 60 mark.
April 14, 201312 yr OMG.. We are what? 99% sure that's not your peak note in that vehicle being you have a wall? Unless your enclosure is over ~24cuft net.... Regardless.. again.. OMG.. and I know the potential to get louder on the meter is there without anymore equipment installation..
April 14, 201312 yr On another note.. How does your windshield react to that at 42hz? Do you see in the near future a replacement requirement?
April 14, 201312 yr Author it has a stripper pole. wind shield does not more hardly at all anymore. and the enclosure is closer to 28 after all displacements.
April 14, 201312 yr Wow.. never used pole before but jesus.. they must do wonders, hehe.... I can tell you now.. most of us do like our ground pounders.. but if u take some couch cushions or whatever big and stuff that port closed.. take a slow resonance sweep of that blazer and see where it peaks at when the port is not effecting the peak, you can see where u need to peak at.. It should be above 50hz easy. Then u can only imagine how much louder you would be on the meter if you sealed literally like 50% of the enclosure off to force it to peak right.. Of course, this is the meter route.. for ground pounding.. you need 100% the largest enclosure possible. Either way, the way it sits right now.. You have accomplished a mobile miracle. Assuming everything else is assumed to stay intact from the pressure, you Da Man, hehe.
April 19, 201312 yr Admin Popular Post 160's is bonkers, and oh by the way, that's a 160 with out the subs having to be reconed.
April 19, 201312 yr 160's is bonkers, and oh by the way, that's a 160 with out the subs having to be reconed. Lulz were had
April 23, 201312 yr Hi very very nice install man super cleanI am wondering how/where did you secure your wall to the truck?
May 6, 201312 yr Hi very very nice install man super cleanI am wondering how/where did you secure your wall to the truck?more like, where did he secure the truck to the wall?? amazing. I need to get my ass to one of these car shows, never sat in anything that looks that loud.
May 6, 201312 yr Author Hi very very nice install man super cleanI am wondering how/where did you secure your wall to the truck? it is bolted throught the floor right above the rear axle.
June 8, 201312 yr Author nice build, looks great . what angle did you cut that ramp at? looks good 58.7°
