  • 1 month later...
  • Replies 265
  • Views 54k
Curious if you ever got clamped measurements of the Crescendo amps at 16v? Also, any chance of this being in Indy June 15/16 for Slamology? I would love to get a demo of this beast!
I second that!! i was curious of the same thing.
something about zcons that make me go nutz!!!!! SSA FTW!
They are now Evils inside :)
with the zcons we clamped 9k out of the pair but that was rising to 5ohm straped at that frequency.
will have to clamp it agian with the new subs (different starting impedence)
did make some pillars for it today as well.
539707_10200451513163258_1717855136_n.jp
also got over the 60 mark.
Thats infucking insane!
OMG.. We are what? 99% sure that's not your peak note in that vehicle being you have a wall?
Unless your enclosure is over ~24cuft net....
Regardless.. again.. OMG.. and I know the potential to get louder on the meter is there without anymore equipment installation..
On another note..  How does your windshield react to that at 42hz?
Do you see in the near future a replacement requirement?
it  has a stripper pole. wind shield does not more hardly at all anymore. and the enclosure is closer to 28 after all displacements.
Wow.. never used pole before but jesus.. they must do wonders, hehe....
I can tell you now.. most of us do like our ground pounders.. but if u take some couch cushions or whatever big and stuff that port closed.. take a slow resonance sweep of that blazer and see where it peaks at when the port is not effecting the peak, you can see where u need to peak at.. It should be above 50hz easy.
Then u can only imagine how much louder you would be on the meter if you sealed literally like 50% of the enclosure off to force it to peak right..
Of course, this is the meter route.. for ground pounding.. you need 100% the largest enclosure possible.
Either way, the way it sits right now.. You have accomplished a mobile miracle.
Assuming everything else is assumed to stay intact from the pressure, you Da Man, hehe.
  • Admin
  • Popular Post
160's is bonkers, and oh by the way, that's a 160 with out the subs having to be reconed.  ;)
160's is bonkers, and oh by the way, that's a 160 with out the subs having to be reconed.  wink.png
Lulz were had :)
Hi very very nice install man super clean
I am wondering how/where did you secure your wall to the truck?
  • 2 weeks later...
more like, where did he secure the truck to the wall??
amazing.
I need to get my ass to one of these car shows, never sat in anything that looks that loud.
it is bolted throught the floor right above the rear axle.
  • 4 weeks later...
nice build, looks great . what angle did you cut that ramp at?  looks good
  • Admin
Bonkers. :)
58.7°
  • 7 months later...
That's what the fuck is up.
