Posted November 29, 201113 yr i need box builder for my subs this is what i need Here's the box info. Sealed box2.4 cubic feetLine box with ~3" thick fiberglass insulation.Subs faced up.if anythin hit me up here or [email protected]
November 29, 201113 yr there are MANY box builders on this site.. go down into the vendor section and ask one of them.You gotta at least categorize your posts.
November 29, 201113 yr Can I ask why you want such a large sealed box? Also the fiberglass won't be worth the added cost in my opinion but can be done if you are set on doing it. Pm your vehicle, RMS power being used, and max dimensions.Thanks, Rick
November 29, 201113 yr Why do you need someone to make a sealed box? A sealed box is the simplest enclosure you can do.
November 29, 201113 yr im just going by what a friend of mine told me Well first question would be: Why sealed over ported? DCON's perform better ported in my opinion. It will be determined by what your goals are.
November 29, 201113 yr Have Rick build you a ported box built to spec. No fiberglass because it will add a lot of extra cost and doesn't matter unless you are competing.
November 29, 201113 yr Well they are subwoofers so they are going to produce bass. If you box is built to SSA specs, it will sound great.
November 30, 201113 yr You will want those subs to be in a ported enclosure. Low end output will improve significantly.
November 30, 201113 yr You will want those subs to be in a ported enclosure. Low end output will improve significantly.Exactly what we're going to do. Ported tuned to ~30hz.
November 30, 201113 yr He's the customer, he gets what he wants. Not rude at all.Yeah we will do whatever is requested, however in this case it was evident that some guidance was needed.
