Posted December 8, 201113 yr I have a stupid question, but can you strap an AQ 2200 to an AQ 1200 and run 2 subs on it or would it put it wayyy out of phase or something
December 8, 201113 yr I have a stupid question, but can you strap an AQ 2200 to an AQ 1200 and run 2 subs on it or would it put it wayyy out of phase or somethingI wouldnt try it, only same wattage amplifiers can be linked togehter. Im pretty sure if it was possible you would of seen multiple people doing it.Ask the owner of AQ is it possible and see what he says since he seems knowledgeable when it comes to amps, let us know what he says.
December 8, 201113 yr Wouldn't recommend it, not sure why you would want to. Even if the designs were similar enough to allow it to be electrically possible you would be limited to the power of the lowest power amp.
December 8, 201113 yr Don't do it. I highly doubt that it would even work, but as mentioned even if it didn't put the amps into protect you will most likely damage one or both amps internally.
