I've decided my next setup would either consist of a single icon 15 or two SA12s, my goal is SQ first but i do want it to be somewhat loud. both setups would be ran off a sundown sax 1200d amp. The setup would go in a 95 BMW 740 the alternator is 140amps the stock battery is rather large. I'm trying to stay in the 1200 watt range. thanks in advance. will post more info about the setup if needed
Welcome to SSA ... :drink40:
What do you have in mind for the Sound Quality section of the system ??
I like your idea of 2 SA 12's, plus it would be nice to have the same products (amp, subs)
:WELCOME:
In your above statement, I would lean towards the ICON, but remember the enclosure will have a major affect on the outcome.
I planned on running a component system with separate mids and Hi's to help. i just needed help with sub woofer portion of the system if that answers your question.
Im looking to get that deep bass sound. I listen to mostly rap and some R/B if that makes a difference
Edited by King740i
Welcome bro and listen to Cableguy and sefugi they both have skillz and cableguy has a crazy SQ build well goodluck bro
