  • Replies 59
  • Views 7.3k
  • There is so much fail in this thread. Wow.
  • What are your box specs? Playing notes below tuning may make the sub bottom out pretty easily. Both of those songs get down to around low 30's which means alot of cone movement..
  • Dude....... jeez.
I am tuned to 40Hz and my SSF is at 10Hz. I never have issues.
Do you go around jammin stuff in the mid to low 30's?
I play a good bit of Bigpimpin91 and DJSNT. Which is all low, 28Hz-38Hz.
Well I guess I can't argue with that. No excursion issues at all?
Edit: Wait bandpass or standard 4th order ported?
Edited by An-i-no
Standard 4th order.
Only issues is full power below 30Hz, and even then it has to be those weird notes. Lol. Make sense?
Standard 4th order.
Completely. I'm tuned to 28 and hit people with 18hz shockwaves lol. I just don't see myself doing it without my ssf or some crazy loading wall setup
There is a meathod to our box madness. Lol. My woofer loads well over a huge frequency range.
I understand how it works...(it being loading) but I'm not quite sure how to manipulate it to my advantage. I just know that subs up port firing to the drivers side = crazy output below 30hz lol
I'm tuned at 30hz and can drop to 20hz full power without bottoming out :) makes for some shocked faces
yeahh.. i dont really wann be a bother at all. it just seems that way because i say the wrong things i guess lol. i mean, when something goes wrong, i tell you guys like it is. idk what im doing, ill admit. im no pro or experienced guy in car audio. but i know most of you guys are :peepwall: seems like my questions irritate alot of you guys, so ill lay off the NUMEROUS questions i have. i also admit that i dont really research when im on here. mostly look at build logs and stuff to get build ideas lol. time for a changeee, agreed? sorry to bother anyone.
my kicker 1000.1 has a adjustable ssf, so thats good :)
Edited by Angelboy863
