I ordered a recone kit w/ basket for a Q. Wondering what all is included with this recone kit--push terminals, bolts for basket to motor, shim, CA glue, etc.? I'd like to have everything on hand when kit comes in.
They expect you to reuse the terminals and the bolts from the sub you are rebuilding. If you started with just a motor and need those additional parts, I would email them about adding to your order.
Use multiple sheets of paper for shims.
No CA glue unless you ordered it from the recone accessories section for $10. You can use Loctite 2 part epoxy for a Q and it will hold great.
Thanks for the info. I ordered glue from them. Starting with motor only. I have the terminals, just no bolts. Anybody know what size/specs bolts used on this sub?
I believe they are M6. Take the motor into the hardware store if you need to verify.
when i got my recone kit for my ssd i upgraded to a 15 and it came with bolts and terminals.
Thanks for info. Be nice to get fresh stuff for my recone.
  • 2 weeks later...
FYI, it came with bolts/screws and terminals. Thanks FI
Wondering if it might be possible that I got the wrong gasket with my kit, assuming there are different gaskets besides the obvious being overall diameter. Are there different gaskets for different Fi subs?
