July 25, 201313 yr Stop worrying about the response curve on winISD lol... You should know by know it is only a very rough guide at best. Not mention the idea behind the response curve will change as your power and wants/needs change.
July 25, 201313 yr Stop worrying about the response curve on winISD lol... You should know by know it is only a very rough guide at best. Not mention the idea behind the response curve will change as your power and wants/needs change.Meh, the response for the new enclosure is somewhat similar. I figured out how my car responds with the subs in that position so i would like the response to have not much more than a db peak from 30~55. I like my response a lot better now but still could be better but i dont have the room to tune my sub any lower or make the enclosure bigger.
July 25, 201313 yr So why not build an SQ system? If you keep pushing for SPL your response will likely get further from what you want with a larger peak to chase the numbers. But you know that already...
July 25, 201313 yr So why not build an SQ system? If you keep pushing for SPL your response will likely get further from what you want with a larger peak to chase the numbers.But you know that already... I could also do what you suggested and use two ports and plug one up, which could drop the tuning to where i want for daily and still get plenty loud and i could unplug the extra port and have it tuned way higher to mess around and get numbers.
July 25, 201313 yr Very true, very true. Or..we can ditch all causes and build something monstrous in that little car
July 25, 201313 yr Very true, very true.Or..we can ditch all causes and build something monstrous in that little car Since it is not technically my vehicle, i cannot do that... Yet anyways
July 25, 201313 yr "Yet" being the operative word here lol You have to do something big..most of my clients are jumping to walls already..... Well Tony had something to do with that I think lmao
July 25, 201313 yr He probably did. But in the next couple of years or so i wouldnt mind doing some evil 15s in a wall
July 25, 201313 yr Tony will have some likely over the winter it looks like.... I'm sure he will want to upgrade to 18s by mid season though lol
August 1, 201313 yr well, the other day i went to dustin's (pro-rabbit) shop to hang out and he sort of talked/forced me into doing finishing my box and doing it his way, which is fine with me. We still have a bit of trimming and bondo work to do but it should be wrapped and, for the most part, done in the next couple of days.
August 1, 201313 yr "Forced" more of a genital nudge....with wood and a saw lmao.... After some touch up cutting and some router work.... will be on it's way to looking sexy again...
August 1, 201313 yr hahaha, you were like this is what were are doing and you should do this and that for wrapping it.
August 1, 201313 yr BTW, thanks for the help today...... and the commentary about my OCD with seeing seams lol Edited August 1, 201313 yr by pro-rabbit
August 1, 201313 yr Force would imply there was resistance lol As I recall... you were like..."Do it!!" lol
August 1, 201313 yr Hahhaha you suggested and i said that would be cool, then you started doing it. Well, actually, amber started doing it.
August 6, 201312 yr Since he is still sleeping lol... here are a few updated pics.. long way to go..but it's a start.
