May 8, 201412 yr drivers side port?? center port with acrylic window and inverted subs?? what ever it is this is AWESOME!!!!
May 8, 201412 yr You go ahead and order your Excursion rear suspension for that Explorer ?? I take it that you have plans to take the MECA "Park and Pound" World Championship with this Awesome Ride.
May 9, 201411 yr Author So you guys can see how massive this is.10 sealed34 ported1" High Grade MDF is used in conjunction with steal.
May 9, 201411 yr Sen... check pm regarding the sub... thought I'd had a response since you have been on ..
May 9, 201411 yr Author Sen... check pm regarding the sub... thought I'd had a response since you have been on .. checking
