Posted January 10, 201214 yr Thought this was pretty awesome, hope it hasn't been posted yet.http://www.pioneerelectronics.com/PUSA/Car/CD-Receivers/DEH-80PRS
January 10, 201214 yr That's sweet:Match the display and key illumination to your vehicle's interior lighting. Over 210,000 colors are available to match the illumination in any car. The key illumination and display illumination colors can be customized separately for an endless number of color combinations.When you ordering it?
January 11, 201214 yr Looks like a great SQ headunit... okay so how do you tell an SQ headunit from a normal unit? "28-Bit Binary Floating-Point DSP and 3-Way Digital Network"does that mean SQ to you or does this? Auto Time Alignment and Auto EQor do they both?just sounds like fancy words to an un-sq'ed geared kind a guy! lol
January 11, 201214 yr ... Sorry?I was mearly asking how you knew that is a great SQ headunit, can you tell me which specs scream SQ to you? I am just asking a question like if I ever decide to use my zapco comps and zapco amps what kind a h/u I should look for although at the same time I am not trying to jack the thread just looking for fast tips.
January 11, 201214 yr Looks like a great SQ headunit... okay so how do you tell an SQ headunit from a normal unit? "28-Bit Binary Floating-Point DSP and 3-Way Digital Network"does that mean SQ to you or does this? Auto Time Alignment and Auto EQor do they both?just sounds like fancy words to an un-sq'ed geared kind a guy! lolIt's definitely geared for an active setup, with the ability to fine tune with time alignment and a more detailed eq.Better FR from speakers in their installed locations, TA to help improve imaging, and eq to adjust for obstructions, peaks, dips.
January 11, 201214 yr Oh my mistake.. Im really not that knowledgeable on what is SQ and whats not.. Let me rephrase.. Looks like a quality HU!.
January 11, 201214 yr ... Sorry?I was mearly asking how you knew that is a great SQ headunit, can you tell me which specs scream SQ to you? I am just asking a question like if I ever decide to use my zapco comps and zapco amps what kind a h/u I should look for although at the same time I am not trying to jack the thread just looking for fast tips.If your using a component set then the active processing isn't something you would care for since your component set comes with a passive crossover network. Not sure if TA would beneficial since it would be going to the entire channel.Of course you could use your speakers without their passive crossovers and go active with this unit, would it be a big improvement, I don't know.
January 11, 201214 yr ... Sorry?I was mearly asking how you knew that is a great SQ headunit, can you tell me which specs scream SQ to you? I am just asking a question like if I ever decide to use my zapco comps and zapco amps what kind a h/u I should look for although at the same time I am not trying to jack the thread just looking for fast tips.If your using a component set then the active processing isn't something you would care for since your component set comes with a passive crossover network. Not sure if TA would beneficial since it would be going to the entire channel.Of course you could use your speakers without their passive crossovers and go active with this unit, would it be a big improvement, I don't know.I think even if you're using a component set, these types of unit deliver WAAAAY better eq options and adjustments. I'd get it even if not going active because I like that control. I'm definitely ordering one when its available. Tax refund and all. Plus some batteries!
January 11, 201214 yr ... Sorry?I was mearly asking how you knew that is a great SQ headunit, can you tell me which specs scream SQ to you? I am just asking a question like if I ever decide to use my zapco comps and zapco amps what kind a h/u I should look for although at the same time I am not trying to jack the thread just looking for fast tips.If your using a component set then the active processing isn't something you would care for since your component set comes with a passive crossover network. Not sure if TA would beneficial since it would be going to the entire channel.Of course you could use your speakers without their passive crossovers and go active with this unit, would it be a big improvement, I don't know.I think even if you're using a component set, these types of unit deliver WAAAAY better eq options and adjustments. I'd get it even if not going active because I like that control. I'm definitely ordering one when its available. Tax refund and all. Plus some batteries!I just turn the treble and bass all the way up and I'm good.
January 11, 201214 yr ^^^ True! LOL. Stef that song BTW sounds amazing in my car. Can't waait to get my tweeters in. ;-)
January 11, 201214 yr ^^^ True! LOL. Stef that song BTW sounds amazing in my car. Can't waait to get my tweeters in. ;-)Oh man, your gonna love it with tweeters.
January 11, 201214 yr I'm really looking forward to this unit.ATM its nigh impossible to play CDs in my car so those USB ports will be nice. And bt is a nice touch too.Wonder when they can be ordered.
January 11, 201214 yr Shogen and stefanhinotethanks for going over that with me and your replies! I have been toying with going a big more on the SQ side of things and seeing if I like it or not. I have also been looking into going active but that still kind a scares me lol! O well when I get a for sure job I will be doing a few more improvements, first being the car LOL!! as you all know or don't my 95 grand am has 390,000km on it which is nearly 250,000miles so it is time now lol! and MikeMartelno worries man I was just wondering!
January 11, 201214 yr Very nice head unit ... I almost bought this ... http://www.crutchfield.com/S-n59hHtwQhQo/p_130DEXP99R/Pioneer-Stage-4-DEX-P99RS.html
January 11, 201214 yr Very nice head unit ... I almost bought this ... http://www.crutchfield.com/S-n59hHtwQhQo/p_130DEXP99R/Pioneer-Stage-4-DEX-P99RS.htmlWhy didn't you buy it?
January 11, 201214 yr Very nice head unit ... I almost bought this ... http://www.crutchfield.com/S-n59hHtwQhQo/p_130DEXP99R/Pioneer-Stage-4-DEX-P99RS.htmlWhy didn't you buy it?Got this ... http://www.kenwoodusa.com/Car_Entertainment/eXcelon/Mobile_Video_n_Navigation/DNX9980HD
January 11, 201214 yr having decals sent to me from Kenwood to go on my truck for this years competition season ...
January 11, 201214 yr Shogen and stefanhinotethanks for going over that with me and your replies! I have been toying with going a big more on the SQ side of things and seeing if I like it or not. I have also been looking into going active but that still kind a scares me lol! O well when I get a for sure job I will be doing a few more improvements, first being the car LOL!! as you all know or don't my 95 grand am has 390,000km on it which is nearly 250,000miles so it is time now lol! and MikeMartelno worries man I was just wondering!I'd help you with sq department in exchange for box services. LOL!
January 11, 201214 yr I think we might have a P800PRS replacement (finally).Lets hopeI doubt it will replace the 800. That's what the P99RS is for.Like I said on Facebook, I don't think the build quality will be near the same as the older PRS's. For the last few years Pioneers haven't been built well, I feel this will be the same with this unit.Another thing I don't like is the built in Bluetooth, to much of a chance for that induce noise to make this a great SQ unit.
January 11, 201214 yr Very nice head unit ... I almost bought this ... http://www.crutchfield.com/S-n59hHtwQhQo/p_130DEXP99R/Pioneer-Stage-4-DEX-P99RS.htmlWhy didn't you buy it?Got this ... http://www.kenwoodusa.com/Car_Entertainment/eXcelon/Mobile_Video_n_Navigation/DNX9980HDOh cool.I think we might have a P800PRS replacement (finally).Lets hopeI doubt it will replace the 800. That's what the P99RS is for.Like I said on Facebook, I don't think the build quality will be near the same as the older PRS's. For the last few years Pioneers haven't been built well, I feel this will be the same with this unit.Another thing I don't like is the built in Bluetooth, to much of a chance for that induce noise to make this a great SQ unit.Wouldn't everything transferred through bluetooth be digital, how would that induce noise?
