January 20, 201214 yr Author This is a build that I've been "helping" aka do for him and it turned out pretty great. In the process of finishing the battery box and some trim panels it's a 21" DP with a shitty ass PSI recone.. I tore off the PSI logo
January 22, 201214 yr quote name='Julian' timestamp='1326944066' post='871955']21hz full blast + 5k = Just curious as to why you did this?
January 22, 201214 yr Julian, have you guys applied resin to the door panels yet?I'm assuming that door panel is plastic from the looks, I strongly suggest scuffing up the plastic, and drilling holes before hand. This will give the resin and mat something to adhere to.
January 22, 201214 yr Just curious as to why you did this?I do believe it was and accident.He was using a usb stick and somewhere in the playlist was a 21hz test tone he forget about, IIRC.
January 22, 201214 yr Just curious as to why you did this?I do believe it was and accident.He was using a usb stick and somewhere in the playlist was a 21hz test tone he forget about, IIRC.Ohhh, dang well that sucks.
January 22, 201214 yr Author Julian, have you guys applied resin to the door panels yet?I'm assuming that door panel is plastic from the looks, I strongly suggest scuffing up the plastic, and drilling holes before hand. This will give the resin and mat something to adhere to.the fabric is actually tucked under a preexisting panel on it and stapled from behind/rontYes indeed destroying the ZCON was an accident
February 2, 201213 yr Author while hooking up my new sax 125.2 I re did some of the wiring.. some how while doing this it shorted... and here's the aftermath..fused the + line running to the battery to prevent any potential repeats of this.
February 3, 201213 yr hahaha You're almost as lazy as me when it comes to fan placement! Love the recone pics!
February 7, 201213 yr Author Might have to re-do it, was pretty cold last night so it didn't dry very fast
