Posted January 26, 201214 yr Plan on sellin my btl 18s..and I ran into a lot of money recently.. Which subs should I go with. Will be walled in a civic 2 21" ia wardens. Or 4 15 btl n2slook at sig for rest of setup Edited January 26, 201214 yr by 14K
January 26, 201214 yr I believe 3 18s will have cone advantage over two 21, but will be close match compared to 4 15s, I believe overall tho, the 15s will provide more output
January 26, 201214 yr I dont know if 3 ports will sound as good as 1 big port though...Who said anything about three ports?
January 26, 201214 yr Author No way I could fit 3 in straight row. I have 45" width, 32" heighth, 17" deep, to play with And thats after about 2" wood on top, bottom, left, right, front, back. Edited January 26, 201214 yr by 14K
January 26, 201214 yr I'm so confused now 14, where did this "port" talk come from? I thought which sub to buy was the debate?
January 26, 201214 yr Same amount of cone area either way so I say go with the n2's you can apply more power
January 26, 201214 yr Author I'm so confused now 14, where did this "port" talk come from? I thought which sub to buy was the debate?Lol it is between the 21s and 15s... The 3 18s is out of the question lol
January 26, 201214 yr 4 15"s. Simple as that.Two woofers CANNOT take 7k daily each. 4 can take 3.5k each daily.
January 26, 201214 yr 4 subs is best for a daily app for sure14k, this is the guy with the 4 DD 91515"s.
January 27, 201214 yr Two woofers CANNOT take 7k daily each. the IA 21's cant ... or your statement is that NO pair of subs can take 7 K daily?
January 27, 201214 yr This: http://www.parts-express.com/pe/showdetl.cfm?Partnumber=265-376 will take 7k mw, even 100000k µW.
January 27, 201214 yr This: http://www.parts-express.com/pe/showdetl.cfm?Partnumber=265-376 will take 7k mw, even 100000k µW.Can't believe I bothered clicking that link. Smh
January 27, 201214 yr This: http://www.parts-express.com/pe/showdetl.cfm?Partnumber=265-376 will take 7k mw, even 100000k µW.troll
