Posted January 27, 201214 yr Does the aq750 have rca? My headunit is cde122 and has rca on the backNot sure about all of this. Thanks
January 27, 201214 yr Author There not in a wiring kit?While i have you hear. I had trouble crimping my ilkumination wires on hu. Is that only for when headlights are on deck lights dim? Or is that a dimmer? IdkMy hu only has illumination
January 27, 201214 yr He's asking about the 'Illumination" wire for his head unit. The lights of the HU should dim whenever you use your gauge dimming switch, if you have one.
January 27, 201214 yr Author Oooh ok. Idc bout that. I couldnt crinp that. Broke the metal they provide oh wellThanks:) man cant wait to buy my setup ;-)
January 27, 201214 yr Oooh ok. Idc bout that. I couldnt crinp that. Broke the metal they provide oh wellThanks:) man cant wait to buy my setup ;-)I think that you'll be happy
January 28, 201214 yr I will be using 2 (10") dcon dvc 4ohmGood so you can wire down to one ohm. Each sub will get at least 375 watts rms.
January 28, 201214 yr Author That was what my data gatheredSo wikk 375 to hit hard? Not two mile radius loud but enough to get a back massage?
January 28, 201214 yr That was what my data gatheredSo wikk 375 to hit hard? Not two mile radius loud but enough to get a back massage?I think they will surprise you how loud they get? Are you using a sealed or ported box?
January 28, 201214 yr Author I shall be using a ported box. Prob 1 cubic as thats what the sub specs say
January 30, 201214 yr Admin With more then ratted power for the Dcon's, I usually suggest the standard size enclosure. With less then ratted, the optimal size is great.
January 30, 201214 yr i would say around 1ft3 should do just fine. Just make sure you have correct port area and tuning for the subs/application and you should be just fine.
January 30, 201214 yr Author Well i will be buying the box. I dont have the tools or skills to go custom box
January 30, 201214 yr Well i will be buying the box. I dont have the tools or skills to go custom boxD C Creations can build you one.
January 30, 201214 yr Our prices on in the vendor section...Here is a link...We also offer a DIY Kit now. Edited January 30, 201214 yr by pro-rabbit
January 30, 201214 yr How are they on pricing?Also what size amp kit. 8gauge?8 Should be enough unless you plan to upgrade later then I would do four. As for pricing you would have to get a qoute from them.
February 3, 201214 yr Author Are you saying you dont like it anymore?Only thing is it will give each dcon 375w. Im having to use a bigger box due to more power. Just gotta watch the gain so i dont fry it
