I'm getting rid of all my car audio to invest in a home audio system. You can check my photobucket account to see images of all items. If you have any questions, feel free to ask.
Photobucket album: Audio for Sale
Alpine PDX4.100--250$
Product Description
4-channel car amplifier
100 watts RMS x 4 at 4 ohms (100 watts RMS x 4 at 2 ohms)
200 watts RMS x 2 in bridged mode (4-ohm stable in bridged mode)
CEA-2006 compliant
Stackable installation design with front-panel controls
Variable high- and low-pass filters (30-400 Hz, 12 dB/octave)
Quick-connect speaker connectors
Class-D amplifier design
MOSFET power and output stages
Fuse rating: 30A x 2
4-gauge power and ground leads recommended wiring and hardware not included with amplifier
Dimensions: (WHD) 10-3/16 x 2-1/2 x 8-1/2
Sundown SAZ-1000D 250$
Technical Details
• 1000W Digital Class-D Linkable Mono Block Amplifier
• Double Sided Through Hole Epoxy PCB
• 1 Ohm Stability
• Efficiency : 86% @ 4 ohm, at 100Hz
• Multi-Way Protection Circuitry (Thermal/Over Current/Speaker Short/Speaker DC Protection)
The SAZ-1000D is our most compact Class-D amplifier and can fit almost anywhere! Don't let the small size fool you as this amplifier packs 1000-watts RMS into a tiny package only 11.5 inches long.
* Digital Class-D Linkable Mono Block Amplifier * Double Sided Through Hole Epoxy PCB * 1 Ohm Stability * Efficiency : 86% @ 4 ohm, at 100Hz * 24dB/Oct Variable Crossover * Multi-Way Protection Circuitry (Thermal/Over Current/Speaker Short/Speaker DC Protection) * RCA Line Input and Master Output * 24dB Octave Crossover Slope * Variable Subsonic Filter * Variable Bass Boost * Variable Low Pass Filter * Variable Phase Shift * Four(4) Gauge Power Supply Connectors * Tested Voltage & THD : 14.4V & Less than 1% THD * Operating Voltage : DC 10V~16V * Wired Remote Controller
RMS power, 2 ohm linkable/dual mono 1800W x 1CH RMS power, 1 ohm mono 1000W x 1CH RMS power, 2 ohm mono 600W x 1CH RMS power, 4 ohm mono 300W x 1CH Signal to Noise Ratio >90dB Low pass frequency crossover 35Hz~300Hz Subsonic filter 10Hz~60Hz Bass boost @ 45Hz 0~18dB Phase shift control 0~180 degree Frequency response 10Hz~350Hz (+/- 1dB) T.H.D @ 4 ohm <0.1% Efficiency @ 4 ohm 86% Fuse rating 25A x 3 Input Sensitivity 200mV to 6V (+/- 5%) Dimensions 252(W) x 58(H) x 294(L)mm
FI SSD 10" 2ohm DVC Fully loaded in 2010 150$
Focal Polyglass 6.5" Coaxial 2-Way Speakers, Model 165CVX $150
Features:
• 2-way 6-1/2" speakers (pair)
• Polyglass woofer with butyl rubber surround
• Rotating aluminum inverted dome tweeter
• Non-resonant ABS/glass fiber basket
• Built-in 12 dB/octave crossover
• Grilles included
• 2-70 watts RMS power range (140 watts peak)
• Frequency response: 60-20,000 Hz
• Sensitivity: 93 dB
Focal K2 Power 165 KF 2-way 6.5" Component 350$
Speaker Specifications:
• 6-1/2" K2 Power Series 2-way component system
• Power Handling:
◦ Peak: 320 watts per set / 160 watts each side
◦ RMS: 160 watts per set / 80 watts each side
• 6.5" Composite Sandwich cone
• Butyl Rubber surround type
• Adjustable tweeter level
• Separate crossovers 12/18 dB/octaves
• 4 ohms impedance
• 1" (25mm) voice coil
• 3-1/3" (85mm) Neodyme Magnet
• Top-mount depth: 2.80" (70mm)
- Comes with TN51 Focal Utopia Tweeter
Focal Polyglass 6.5" Component (No tweeters, Focal Utopia Crossovers) 80$
  • 10 months later...
Are you firm on the sundowns price?
Dude look at the date of the topics before you bump them.
Edited by jay-cee
