February 5, 201214 yr Fuse to the wires capacity that was If over current happens the wire can catch fire
February 5, 201214 yr Actually what amp and what size wire more info please also does the amp have on board fusing
February 5, 201214 yr Author Actually what amp and what size wire more info please also does the amp have on board fusingMechman 300amp and zero gauge wire to the battery and ground to the battery.
February 5, 201214 yr Actually what amp and what size wire more info please also does the amp have on board fusingMechman 300amp and zero gauge wire to the battery and ground to the battery.Is this fuse going in between the alternator & battery, or battery & amplifier?Are you using 1/0 wire from the battery to the amplifier?Does the amplifier have on-board fusing?
February 5, 201214 yr Author Actually what amp and what size wire more info please also does the amp have on board fusingMechman 300amp and zero gauge wire to the battery and ground to the battery.Is this fuse going in between the alternator & battery, or battery & amplifier?Are you using 1/0 wire from the battery to the amplifier?Does the amplifier have on-board fusing?Alt and battery.
February 5, 201214 yr Actually what amp and what size wire more info please also does the amp have on board fusingMechman 300amp and zero gauge wire to the battery and ground to the battery.Is this fuse going in between the alternator & battery, or battery & amplifier?Are you using 1/0 wire from the battery to the amplifier?Does the amplifier have on-board fusing?Alt and battery.300a anl fuse will work fine.
February 5, 201214 yr Author Actually what amp and what size wire more info please also does the amp have on board fusingMechman 300amp and zero gauge wire to the battery and ground to the battery.Is this fuse going in between the alternator & battery, or battery & amplifier?Are you using 1/0 wire from the battery to the amplifier?Does the amplifier have on-board fusing?Alt and battery.300a anl fuse will work fine.Thank you much kind sir.
February 5, 201214 yr Author Actually what amp and what size wire more info please also does the amp have on board fusingDont know.
February 5, 201214 yr What size fuse should be between the battery and amp?Actually what amp and what size wire more info please also does the amp have on board fusingDont know.so I assume that your first post was a type-o then as you asked for fusing size between the battery and amp but you meant alt. lolalso if my first statement holds true then, if they wire is capable of 300amps use a 300amp fuse! and always fuse to the wires capacity!
February 5, 201214 yr Author What size fuse should be between the battery and amp?Actually what amp and what size wire more info please also does the amp have on board fusingDont know.so I assume that your first post was a type-o then as you asked for fusing size between the battery and amp but you meant alt. lolalso if my first statement holds true then, if they wire is capable of 300amps use a 300amp fuse! and always fuse to the wires capacity!Thank you.
February 5, 201214 yr I will probably use a 250 for now. 250 will be fine! it is what I used back in the day for years becasue when I went to purchase 300A they were out and I never got around to buying a new one/ upgrading lol
February 5, 201214 yr If you use a 250 amp fuse, how will the alternators 300amps be able to flow through? The fuse will break. Sounds like a bad time to me.
February 5, 201214 yr Author If you use a 250 amp fuse, how will the alternators 300amps be able to flow through? The fuse will break. Sounds like a bad time to me.I dont need 300 amps 225 will get me buy unless voltage drps alot.
