What size fuse should be between the battery and amp?
Fuse to the wires capacity that was If over current happens the wire can catch fire
Whats the wire rated at?
Actually what amp and what size wire more info please also does the amp have on board fusing
Mechman 300amp and zero gauge wire to the battery and ground to the battery.
0. gauge wire
Is this fuse going in between the alternator & battery, or battery & amplifier?
Are you using 1/0 wire from the battery to the amplifier?
Does the amplifier have on-board fusing?
Alt and battery.
Alt and battery.
300a anl fuse will work fine.
Alt and battery.
Thank you much kind sir. :fing34:
Dont know.
300 amps.
Dont know.
so I assume that your first post was a type-o then as you asked for fusing size between the battery and amp but you meant alt. lol
also if my first statement holds true then, if they wire is capable of 300amps use a 300amp fuse! and always fuse to the wires capacity!
Dont know.
Thank you. :drink40:
I will probably use a 250 for now. :eek5wavey:
250 will be fine! it is what I used back in the day for years becasue when I went to purchase 300A they were out and I never got around to buying a new one/ upgrading lol
If you use a 250 amp fuse, how will the alternators 300amps be able to flow through? The fuse will break.
Sounds like a bad time to me.
I dont need 300 amps 225 will get me buy unless voltage drps alot. :fing34:
