February 9, 201214 yr I suggest u get something with a 1000rms.. From my personal exp anything less then that is ' meh ' , is this ur first system??This statement is just silly.
February 10, 201214 yr Author I suggest u get something with a 1000rms.. From my personal exp anything less then that is ' meh ' , is this ur first system??Ok, then what would you suggest, i have 600$ to spend on 2 subs and a amp...open fo suggestions but you kinda just was like eh sounds dumb but didnt offer what you though would be better in my price range,
February 10, 201214 yr I suggest u get something with a 1000rms.. From my personal exp anything less then that is ' meh ' , is this ur first system??Ok, then what would you suggest, i have 600$ to spend on 2 subs and a amp...open fo suggestions but you kinda just was like eh sounds dumb but didnt offer what you though would be better in my price range,In that price range the DCON's are a good option. Can you fit a single 15 ported? If you can, a single ICON 15 would be another good option.
February 10, 201214 yr I have 2 Dcon 12's running 2 ohms on a Aq1200d and they get plenty loud. With your budget I would suggest a MB Quart Onx1.1000D and with the money you save you can use it towards decent wiring.
February 10, 201214 yr Author ok. so here is what ive come down to.The Amp im buying is a power acoustic 2000/1 BAMFat 2 ohms it puts out 900rmsSo with that said, im torn between 1 15" Fi BL + will 304$or1 ICON 15'Both i think would perform well on the given amp.Whats my better option for spl?
February 10, 201214 yr ok. so here is what ive come down to.The Amp im buying is a power acoustic 2000/1 BAMFat 2 ohms it puts out 900rmsSo with that said, im torn between 1 15" Fi BL + will 304$or1 ICON 15'Both i think would perform well on the given amp.Whats my better option for spl?Between the two, if they are properly setup the Bl should be better for spl. I would look for a different amp though.
February 11, 201214 yr Author ok. so here is what ive come down to.The Amp im buying is a power acoustic 2000/1 BAMFat 2 ohms it puts out 900rmsSo with that said, im torn between 1 15" Fi BL + will 304$or1 ICON 15'Both i think would perform well on the given amp.Whats my better option for spl?Between the two, if they are properly setup the Bl should be better for spl. I would look for a different amp though.reason why? i dont really have the money to spend much more then that, and has good reviews and is decently priced. + id rather give my sub a little less juice then have to downgrade on my sub to buy a pricier amp.
