Posted February 11, 201213 yr posted this else where but, looking for as much in put as possible Well ladies, its time to add some more batteries. I'm plan on going from 1 AT3000.1, to twoCurrent electrical is a 230 amp alt, stinger SPP1200 under the hood, and an HC2000 in the trunk with 4 runs of 0gaFull tilt daily I might see 14v flat as long as I keep it revved lol. Lowest I saw it drop while metering, was 13.5 but I let of the gas... But it seemed to stay at 13.8 or higher after a long burp staying revved.So I have options for batteries mainly, just adding a second to the rear. I'm considering a D3100 since its about the biggest I can get (max cubic inches is 800 per batt in usaci) and is extremely powerful. I was considering a SK-BT140, but it comes out to 1000cubic inches.So two questions, could I get away with just adding a D3100?Or is there a better battery under 800 cubic inches. I'd rather not get rid of the kinetik yet.I do not plan on going full tilt daily as my 12s on the single 3k are pretty loud full tiltalso I will be running the amps @1ohm each. Might try to trade for a saz4500, not looking good though.
February 11, 201213 yr U would wanna use the same batteries in the back so if u have a hc2000 get another one of those. Dont get one 2000 nd one 3100!!
February 11, 201213 yr U would wanna use the same batteries in the back so if u have a hc2000 get another one of those. Dont get one 2000 nd one 3100!!why?
February 11, 201213 yr U would wanna use the same batteries in the back so if u have a hc2000 get another one of those. Dont get one 2000 nd one 3100!!why?X2 on that one. I would think most of the strain would be put on the 3100 anyway. Edited February 11, 201213 yr by Fearz
February 11, 201213 yr Author U would wanna use the same batteries in the back so if u have a hc2000 get another one of those. Dont get one 2000 nd one 3100!!why?X2 on that one. I would think most of the strain would be put on the 3100 anyway.I''ll be running the amps off the d3100, using 8 0g input terminals.the batteries are of the same material, its wet cell and dry cell. my concern is if the d3100 will be enough, or if there's a stronger battery but under 800 cubic inches
February 11, 201213 yr what subs are you going to use as i know thoses d6s cant take all that power lol
February 11, 201213 yr Author what subs are you going to use as i know thoses d6s cant take all that power lolthey will strapped @4 lol I wanna see how long they last lulzwarden 15s practically for free and it has nothing to do with the contest
