posted this else where but, looking for as much in put as possible
Well ladies, its time to add some more batteries. I'm plan on going from 1 AT3000.1, to two
Current electrical is a 230 amp alt, stinger SPP1200 under the hood, and an HC2000 in the trunk with 4 runs of 0ga
Full tilt daily I might see 14v flat as long as I keep it revved lol. Lowest I saw it drop while metering, was 13.5 but I let of the gas... But it seemed to stay at 13.8 or higher after a long burp staying revved.
So I have options for batteries mainly, just adding a second to the rear. I'm considering a D3100 since its about the biggest I can get (max cubic inches is 800 per batt in usaci) and is extremely powerful. I was considering a SK-BT140, but it comes out to 1000cubic inches.
So two questions, could I get away with just adding a D3100?
Or is there a better battery under 800 cubic inches. I'd rather not get rid of the kinetik yet.
I do not plan on going full tilt daily as my 12s on the single 3k are pretty loud full tilt
also I will be running the amps @1ohm each. Might try to trade for a saz4500, not looking good though.
U would wanna use the same batteries in the back so if u have a hc2000 get another one of those. Dont get one 2000 nd one 3100!!
why?
why?
X2 on that one. I would think most of the strain would be put on the 3100 anyway.
Edited by Fearz
why?
I''ll be running the amps off the d3100, using 8 0g input terminals.
the batteries are of the same material, its wet cell and dry cell.
my concern is if the d3100 will be enough, or if there's a stronger battery but under 800 cubic inches
what subs are you going to use as i know thoses d6s cant take all that power lol
they will strapped @4 lol I wanna see how long they last lulz
warden 15s :) practically for free :) and it has nothing to do with the contest
