Yep, another build log for my Hyundai sleepwerd4.gif Old build log is here.
Keeping some old stuff and adding some new stuff.
Old -
HU: Kenwood something of another Pioneer DEX-P99RS
Synthesizer: ZED RA
Battery: XS Power D3400
Sub: ZCON 15D2 Sundown 18" Z.3(2) Fi Audio IB315
Sub amp: DC Audio 2.0K DD M3a Sundown Audio SAZ1500D v.3
Alternator: 200A Excessive Amperage Ohio Generator 270a
New -
Front stage mid: (4) Dayton Audio RS100T-8 4" Reference Woofer Truncated Frame Jl Audio 4"
Front stage tweeter: (2) Dayton Audio RS28F-4 1-1/8" Silk Dome Tweeter With Truncates Plates LPG soft domes
Front stage midbass: (2) Dayton Audio RS180-4 7" Reference Woofer Dayton Audio RS225-4 8" Reference Woofer JL Audio ZR800CW
Front stage amp: (3) Aura RPM2300 RPM Arc Audio KS 900.6
Old pics of currently installed equipment that will remain for now.
D3400 and 1/0 HPM
Ground strip located near head unit that is routed directly to battery. This used for the HU, RA, relay and volt meter.
I have the relay, remote distribution strip, fuse block and IPod in the glove box.
ZED Audio RA mounted in a factory compartment
Edited by edouble101
  • Replies 453
  • Views 47.1k
Some new stuff :dancing:
Tuned in for the front stage goodness. Doing vertical arrays with the 4" mids?
I want those amps. :wub:
Edited by stefanhinote
The tweeters will be mounted in the apillars at ear level. The midrange drivers will be mounted two per side in the footwells (not kick panels). The midbass drivers will be mounted in the doors.
More pics to come as this build gets off, soon I hope!
Yes the mids will be mounted in the footwells, two per side. That is why I went with the truncated frames. I have truncated plates for the tweets too just to minimize mounting width.
Nice I ordered a few of the circular dayton mids the other day. Good luck man, looking forward to your progress.
Cant go wrong with Dayton Audio.
This build will take a while. Mostly because it is 9 degrees in my garage :sneeze:
nice stuff edub... what's the crossovers look like on them amps?
One or the other: Variable 18 dB per octave low-pass crossovers 50-250 Hz. Variable 18 dB per octave high-pass crossovers 50-250 Hz.
I will be using a processor. Not sure yet. Dpeends on price and features. The ARC maybe +$3000 :WTFBubble: Probably either the RF 3sixty.3 or the JBL MS-8.
Ahhh... I see...
I like what you did here, looks great. :fing34:
Thanks.
What is up next is to redo the sub stage setup.
Thanks.
Still using the zcon?
Thanks.
Yep keeping the ZCON. I will be using it forward firing with an 8"x12" slot port through the rear deck.
Thanks.
Awesome that seems like it will be much better. :fing34:
  • 3 weeks later...
I haven't done anything with this build other than sell the ZCON. Stepping up to a better substage, should be interesting :)
Dreaming of warmer weather so I can tear into this!
What is this better "substage" going to be? Hard to beat the Zcon.
That's what i was wondering. Been thining of getting one of those amps, just don't know what I would do with it!
Quit using the word: "Substage", it's making me batty. :P
  • 2 weeks later...
I definitely disagree and I have owned a ZCON.
Got my 18" Z.3 today. By far the best looking sub I have seen.
Not too many people going to like that comment peepwall.gif Would you be willing to swap only the subs in that enclosure that was built for the zcon just for shits and giggles. oh wait, you can't because you got an 18"!! :o
Edited by Sencheezy
The Z is an 18. Looks good man.
Not too many people going to like that comment peepwall.gif Would you be willing to swap only the subs in that enclosure that was built for the zcon just for shits and giggles. oh wait, you can't because you got an 18"!! ohmy.png
The ZCON inst going to suit everybody's goals. A lot of people that have used it like it, I dont.
I am very impressed :)
Not a beer drinker?
