Arc Amps never fail whenit comes to control over things. Looks great, I also 2nd that photo looks titts
I think the P99RS and the KS900.6 will be a winning combo
Too overwhelming for me! But if your into that stuff, I know you will spend hours tweaking. The main reason I have avoided the 100% SQ route is simply becuase I find it overwhelming. Also, practically ever song you play, or I play from my ipod will come from a different source. What this means is, every song that I play, I will be forced to make some kind of minor tweak, to achieve the same SQ as the song before. But thats just me.
or you could just be tuning like 3-4 frequencies for the most part... taper off the highs/tone them down and +/- bass .... getting the right tuning off of what you REGULARLY listen to is the best idea if it is solely for your enjoyment and not a judges.
  • Replies 453
  • Views 47.1k
I have a couple tools to help me with tuning.
Dayton Audio EMM-6 microphone, Art preamp, TrueRTA software and a collection of Autosound 2000 tuning CD's. There are many useful tuning techniques discussed over on DIYMA that I will be exploring as well.
My goal is to have the best soundstage possible.
Damn man you are going all out! Should be awesome when you are done.
I have always dreamed of having excellent stereo imaging and a deep/wide soundstage in a vehicle. Gonna give it hell!
Damn yo, :shitjustgotreal:
Good for you man. I'm going for something similar. I need that deck haha, hopefully sometime soon.
I will be looking for your build log :)
Goodness gracious....! Well you know the rest.
So I have been debating on weather or not to run the RS100T full range without a tweeter. I could mount two per side in the a-pillars.
OR
I could do a MTM setup in the a-pillars......
I swapped out my RS180-4 for RS225-4. Midbass output should be plentiful :)
RS180-4 on left, RS225-4 on the right
Have you read of others being able to use them full-range? Of course on on-axis.
On the other hand, I would definitely wonder how a mid, tweeter, mid arrangement in a car would do. :D
On the other hand, I would definitely wonder how a mid, tweeter, mid arrangement in a car would do. biggrin.png
Would be a waste of the P99RS and KS900.6 to run a two way front stage.
I think a MTM is in order!
You're insane... I'm down for an open relationship with you if your wife is okay with it edub??? ThatWasGay.gif
looks more and more interesting
I am leaning more and more towards a variance of a MTM setup in the a-pillars. Probably gonna happen :)
Depends on how much money you have ehh.gif LOL
lol ^^^
damn this is gonna have some SERIOUS SQ... wish i could hear it when its done..
lol ^^^
I WILL hear this system when its done... I will creep down to edub's house if need be... Then he can tell me how proud I should be of my poor man's poop fart sounds.
lol ^^^
I hope so!
No doubt man. We can get together to tune your setup as well.
The plan of attack thus far (hahaha I used thus)
1. Drop headliner to fix broken roof brace
2. Gut out interioir
3. Install P99RS
4. Install KS900.6
5. Aim the RS100T-8's in the a-pillars
6. 'Glass the RS100T's
7. Aim the RS28F-4's
8. 'Glass the RS28F-4's
9. Build door pods for the RS225-4's
10. Tune!
Hopefully have 1-5 done by Easter Monday.
Edited by edouble101
lol ^^^
I hope so!
3. Install P99RS
4. Install KS900.6
10. Tune!
:OhYeah:
A couple helpful fellas on another forum pionted out that my port opening was too close to the bottom wall Doh.gif I had 3" of clearance.
So, to my dismay I took the enclosure apart and squeezed another 1" of clearance for a total of 4". Not too sure it will help any but hopefully it is good enough for my goals.
After more research and better judgement, I decided that an aero end was necessary on both ends of the port. Test fitting the flared aero on the rear deck.
After literally hours of test fitting, trimming and test fitting, I finally have the rear deck cover modded for the port. I will be making a trim piece out of floral foam and carpet to make it look better.
I received my alt back from Excessive Amperage. For no charge he modified the alt for an external regulator and supplied the regulator!
M3a? You have room for all that equipment???? Holy shit no trunk for you!!lol
Everything is coming along great! Keep the progress coming
Both amps are going under the seats. Still have a 'lil trunk space left. Mostly pissed that I wasn't able to fit my spare tire :(
Thanks bro
Thanks bro
Under your seats? I don't see that?!?!?! No on sits in the back seat???
Once that trim piece is in for the aero, that's going to look sick. ;)
Both amps are going under the seats. Still have a 'lil trunk space left. Mostly pissed that I wasn't able to fit my spare tire sad.png
Thanks bro
Under the front seats. I will be making a false floor for rear seat passenger's feet.
I have another D3400 that will be mounted in the trunk.
