Once that trim piece is in for the aero, that's going to look sick. wink.png
I hope so. It should be pretty simple to make. I plan on carving the shape I want out of floral foam them covering it in carpet.
  • Replies 453
  • Views 49.7k
So many options in this case. Something I could consider "therapeutic" when making, verse getting burnt out making door pods, etc.
Too bad PA is a bit far from me.
I started fabbing the trim piece. Isnt quite as simple as I thought. Going to need a little bondo on this one. Like you said, lots of options. I am might cover it in vinyl instead of carpet.
You could always fly up here and help me :)
Edited by edouble101
lookin good!!... i wonder how your back window is gonna like the port right there lol
We will see!
I made a little shelf for the voltage regulator to sit on. I welded it to a factory bracket then painted it with rubber undercoating (top and bottom)
I integrated a 88mm idler pulley into the factory alternator serpentine system to increase alternator belt wrap.
Here is a pic of my previous install. I made a fake faceplate using the factory radio face.
I wanted to change things up a little. Crutchfield sent me an install kit with my P99RS but it was cracked.
I removed the fake factory controls and used the bottom tray. I also relocated my voltage meter. The P99RS has a built in voltage display but I wanted to used another since I am not familiar with the accuracy on the P99RS voltage read out.
Looking good. already put the stinger meter in, otherwise I was going to say just compare the voltage read out from the deck to a dmm.
Nice bracket, and I don't think I'd have the balls to fab up another idler pulley. :P
Nice bracket, and I don't think I'd have the balls to fab up another idler pulley. tongue.png
Can never have too many voltage meters smile.png After I am sure the P99RS is reading right I will more than likely remove the other one.
Did you have an issue with an idler pulley setup you made?
No, it's just something I wouldn't rig up. :P
lol i love that stock radio cover to hide your cd player... i like that :cool:
Thanks. It has been holding up well over the year I had it like that.
I started working on a battery box for my rear battery. Not finished yet.
You have so many deer always at your place!
*Posting this while making a dryer for jerky*
Edited by stefanhinote
They can almost be considered pets lol. We have a better chance of seeing deer when we look out a window than not.
so many deers lol
so many deers lol
The plural form of 'deer' is still 'deer' ;)
so many deers lol
lmao!!!
The battery is mounted.
Hard to see it in a picture. The battery is mounted under the sub enclosure. I want to kick myself in the ass for not designing an enclosure that allows me to use the spare tire well for the spare tire sigh.gif Major design f'up on my part.
Plan of attack:
1. Mount amps.
2. Fix roof brace issue
so many deers lol
batt box looks good edouble :)
Edited by 16K
The amps are mounted. I still need to build my false floor. The 900.6 is powering my component set for now.
Up next:
Make a false floor, fix roof brace and finish making a trim panel for the aero port. After that is front stage smile.png
Looks amazing, what will you do when changes are needed to be tweaked?
Thanks
All controls are assessable with the seats bolted down
