Posted February 14, 201213 yr got a big boner right now cant wait to get that beast in... igot the dual 1 flatwind,cooling,daily option... someone told me the d2 was better than the d1 just because the d1 has 1000rms and the d2 has 1500 how tru is that ? i know you got more wiring options with the d2 but it cant be that bad right?? anywho im going to be running at least 300 maybe 500rms over ,would you guy consider going over rated rms???
February 16, 201213 yr got a big boner right now cant wait to get that beast in... igot the dual 1 flatwind,cooling,daily option... someone told me the d2 was better than the d1 just because the d1 has 1000rms and the d2 has 1500 how tru is that ? i know you got more wiring options with the d2 but it cant be that bad right?? anywho im going to be running at least 300 maybe 500rms over ,would you guy consider going over rated rms???What amp are you running? What does your final impedance need to be?
February 16, 201213 yr got a big boner right now cant wait to get that beast in... igot the dual 1 flatwind,cooling,daily option... someone told me the d2 was better than the d1 just because the d1 has 1000rms and the d2 has 1500 how tru is that ? i know you got more wiring options with the d2 but it cant be that bad right?? anywho im going to be running at least 300 maybe 500rms over ,would you guy consider going over rated rms???As has been stated, they are the same RMS. You don't ever need to do that unless you already own the amplifier then look between 500-1500w and you should be fine. What enclosure type are you going to use?
February 17, 201213 yr You will be fine but it also depends on your enclosure. What will you have it tuned at?
February 23, 201213 yr Author im getting the brz1700.1 sub wired to one ohm and im getting dave the box guy to build a box soon,im still waiting on sub to come in its been almost two weeks now but im in no rush just getting antsy.
