Posted February 17, 201214 yr I know there is a Fairly large alt stock, I'm looking for something larger, what would be largest one you guys could do and for how much?Thanks
February 17, 201214 yr Author You hold 13's with 5,000W!!! Why do you need a bigger alt?low 13's high 12's... because I plan on adding more power....The stock alt is almost 200A...
February 17, 201214 yr You hold 13's with 5,000W!!! Why do you need a bigger alt?low 13's high 12's... because I plan on adding more power....The stock alt is almost 200A...More power
February 17, 201214 yr Author You hold 13's with 5,000W!!! Why do you need a bigger alt?low 13's high 12's... because I plan on adding more power....The stock alt is almost 200A...More power For the wall!
February 18, 201214 yr Julian I've asked the very same thing man. They said that the 270a is a "proven" alternator and recomends that I remove A/C and run mulitple alts Edited February 18, 201214 yr by Sencheezy
February 18, 201214 yr Author Julian I've asked the very same thing man. They said that the 270a is a "proven" alternator and recomends that I remove A/C and run mulitple alts I'm not sure I could fit that large of an alt.. I dunno which is the problem plus it's a new car and new engine so IDK if they have one for it.
February 18, 201214 yr Julian I've asked the very same thing man. They said that the 270a is a "proven" alternator and recomends that I remove A/C and run mulitple alts I'm not sure I could fit that large of an alt.. I dunno which is the problem plus it's a new car and new engine so IDK if they have one for it. hmmm, if not, what would ya do? Edited February 18, 201214 yr by Sencheezy
February 18, 201214 yr Author Julian I've asked the very same thing man. They said that the 270a is a "proven" alternator and recomends that I remove A/C and run mulitple alts I'm not sure I could fit that large of an alt.. I dunno which is the problem plus it's a new car and new engine so IDK if they have one for it. hmmm, if not, what would ya do?lots more batteries and external charging on a regular basis probably.
February 18, 201214 yr Julian I've asked the very same thing man. They said that the 270a is a "proven" alternator and recomends that I remove A/C and run mulitple alts I'm not sure I could fit that large of an alt.. I dunno which is the problem plus it's a new car and new engine so IDK if they have one for it. hmmm, if not, what would ya do?lots more batteries and external charging on a regular basis probably.hmmmm, maybe you could send in your current alt to get "beefed" up?
February 20, 201214 yr At this time I do not have a unit for this application. Most applications will run 1-2 years behind the new applications.
February 20, 201214 yr Author At this time I do not have a unit for this application. Most applications will run 1-2 years behind the new applications.
