Posted March 14, 201214 yr Simple question...what is the best way to break them in? Any specific notes i should try...maybe a sweap? 30hz-100hz? Sumthing like that?
March 14, 201214 yr What subs do you have and why are you trying to break them in?The best way to break them in is to play them at a loud, but safe, listening level. Just as you would when they are broken in.
March 14, 201214 yr This question has been asked a 103845937 times. If you would like, you can search key words of your question into the search bar and can see many results that I believe could be of some assistance.
March 14, 201214 yr So just use them...simple...Correct.(Except if you have a digital desings 95 or DD Z series subwoofer and want to overpower them in a small enclosure. Then you need to be gentle in the beginning because the spiders are too stiff.)
March 22, 201214 yr if its a really stiff subs the fastest way to me was to have the subs out of the box in free air & play 20hz cycles at low volume for a couple hrs per day until they loosen up
