Posted March 26, 201214 yr I'm looking to make some buss bars out of aluminum.The buss bars will span two D3100's ~13" for each positive and ground, I was wondering what size and type of aluminum I should go with.I'm not sure how thick or wide of buss bars should I get? I was considering 1 Inch thick by 2 inches.
March 26, 201214 yr Where are you going to get it from? If you have the funds I highly suggest copper if you can.
March 26, 201214 yr Author Where are you going to get it from? If you have the funds I highly suggest copper if you can.I was considering but the local place doesn't stock it IIRC.But Aluminum is cheap
March 26, 201214 yr Author 1" x 2" Aluminum bar stock will have no voltage drop...But would that be excessive though?
March 26, 201214 yr Are you ing to drill holes to put your wire in like Steve did or are you going to crimp ends on your wire and use bolts to the bars?
March 26, 201214 yr Author Are you ing to drill holes to put your wire in like Steve did or are you going to crimp ends on your wire and use bolts to the bars?I am going to drill/tap holes and use bolts to hold down the terminals
March 26, 201214 yr If you have no luck finding what you want let me know I have something that will work for you.
March 26, 201214 yr Author If you have no luck finding what you want let me know I have something that will work for you.www.metalbythefoot.com is local so I can get Aluminum for cheap.. around 1$/ft lol.
March 26, 201214 yr If you have no luck finding what you want let me know I have something that will work for you.www.metalbythefoot.com is local so I can get Aluminum for cheap.. around 1$/ft lol.Ok, that is going to be cheaper then shipping you copper for all the more you need.
March 26, 201214 yr I used 3/8 x 1-1/2" for mine. As far as the grade, or type of aluminum just go with 6061-t6.
March 26, 201214 yr I use Grade 6061 also. Grade 1100 is the best conductor as far as i know but for the price, 6061 is by far the better choice.Aluminum can be purchased and used as is without fear of it oxidizing on you anytime soon.Non treated copper can oxidize in just a week so you would need to spray or apply a product to resist oxidation and assume you applied it perfectly.Also, if you want to know how large of a buss bar you will need, i can help with that.A 1" thick x 2" wide bar can handle current continuous up to ~1,500A. This rating, if i remember right, allows the aluminum to reach 140F at this rating.
