I have a 08 Tundra that I want to push two 10's in a ported enclosure the SD's would save me some space but my issue is
I don't mind losing some leg room for the SA's but will my Arc Audio 2500 XXK at 1150 watts of clean power be enough
to push SA's? or will It push the SD's more efficiantly.
In other words what is better for this amp SD's or SA's
this thing is new in the box I've had it lying around for a while it's a good amp
and my budget can't afford a newer more powerful one
no such thing as underpowering a subwoofer.
gorgeous amp you show off lol
xEleventybillion. Go Ahead And Run The SA's If You Have The Space And The Budget.
Thank you for your replys, I suppose if I go with the shallow mounts I'll always be wondering or regretting not going with the SA's.
I've had that Arc amp close to 6 years, I can't wait to see it push some Sundown's.
Of those two you mentioned, I would choose the SA series every time as long as there is plenty of space.
  • Admin
Very nice amplifier.
I have two sa12s I might be looking to sell.
