April 9, 201214 yr Author i wish that was it but it's the subs and I noticed the highs were way to loud for the amount of bass and certain things that vibrated, don't anymore. also the bass will increase the longer the amp is on
April 9, 201214 yr Author could be a voltage issue aswell....I got three kinetic batts that reach the amp at 14.7v
April 9, 201214 yr Have you checked all sub wire connections, just something to check make sure the solder on the leads is not cracked loose etc.
April 9, 201214 yr Author Have you checked all sub wire connections, just something to check make sure the solder on the leads is not cracked loose etc.I've got P3's no solder connections but maybe the springs vibrated the wire out I.ll go check and get back in a little bit.
April 9, 201214 yr Have you checked all sub wire connections, just something to check make sure the solder on the leads is not cracked loose etc.I've got P3's no solder connections but maybe the springs vibrated the wire out I.ll go check and get back in a little bit.He's speaking of the leads soldered to the driver. Don't worry about your spring terminals. There will never be enough vibration for them to loosen.
April 9, 201214 yr Have you checked all sub wire connections, just something to check make sure the solder on the leads is not cracked loose etc.I've got P3's no solder connections but maybe the springs vibrated the wire out I.ll go check and get back in a little bit.beat me to it^ Edited April 9, 201214 yr by djtomczak
April 9, 201214 yr Author whats your set up aswell.. have you metered the OHM load at the amp.. big three, batt bank of kenetics, RF T6002 birth sheet 788 to 2 P3's seriesed then paralleled and bridged at 4 Ohms
April 9, 201214 yr Author Have you checked all sub wire connections, just something to check make sure the solder on the leads is not cracked loose etc.I've got P3's no solder connections but maybe the springs vibrated the wire out I.ll go check and get back in a little bit.He's speaking of the leads soldered to the driver. Don't worry about your spring terminals. There will never be enough vibration for them to loosen.tinsel leads to the spider?
April 9, 201214 yr whats your set up aswell.. have you metered the OHM load at the amp.. big three, batt bank of kenetics, RF T6002 birth sheet 788 to 2 P3's seriesed then paralleled and bridged at 4 OhmsDoesn't answer his question fully Breaking in/wear of the subs could have altered the load. Edited April 9, 201214 yr by djtomczak
April 9, 201214 yr Author whats your set up aswell.. have you metered the OHM load at the amp.. Loads side, speaker out? sound on or off , how to ?
April 9, 201214 yr Author everything off.. set your DMM to ohm. and red on the + and black on the -Little more specific please
April 9, 201214 yr Take you DMM, set it to ohms. With everything off: place the positive, red, lead on the positive terminal where your speakers connect to your amp, and the negative, black, lead to the negative terminal where your speakers connect to the amp. Edited April 9, 201214 yr by djtomczak
April 9, 201214 yr Author Take you DMM, set it to ohms. With everything off: place the positive, red, lead on the positive terminal where your speakers connect to your amp, and the negative, black, lead to the negative terminal where your speakers connect to the amp.Can I check the ohms on the speakers as well and what should they read and why
April 9, 201214 yr you could if you disconnect the wires from them and check each coil. they should read close to what they are rated at. Either two or four.
April 9, 201214 yr Author what about the amp what should they read Edited April 9, 201214 yr by Cant Get Enough
April 9, 201214 yr You check the amp with the speakers connected to it. It should read what you want it to be wired to. Patients level is lowering....
