Posted April 11, 201214 yr i was thinking of getting a BTL n2 15'', an ported box from this website: http://www.klausaudi...oofer-boxes.php, im not sure what amp im getting but something like a 2000W-2200W, then im getting new battery, big 3, and a high output alternator (250 amps), also im currently looking for new navigational system and speakers. i have a 2005 cadillac escalade esv so i got plenty of room.i was just wondering if anyone has any good ideas for the amp and speak system. i just need some decent speakers and amp.also what would you recommend for box volume? Edited April 11, 201214 yr by lib
May 15, 201213 yr Sounds like your on the right track. The most important part of your system is the electrical, so make sure you have the wiring done correctly and enough juice to run everything. Look into a big battery, as big as you can fit, from whatever brand suits your budget. Most will do the job. Any additional batteries to be mounted anywhere in the passenger cabin are helpful and encouraged. Big badass cable throughout. Stick with a reputable amplifier brand like AQ, Crescendo, Sundown, Cactus, and buy the biggest one you can afford and hang on bc that N2 will do serious work.The more steps you skip the higher the chance something will break and I guarantee it'll cost more in the end that way. A "safer" way to get louder is to add more woofers on less power but it costs more money and takes up more room. But two Q 15s on 1000 would be like a btl 15 on 2k
